Adapting powered pc speakers to hi fi speakers
Adapting powered pc speakers to hi fi speakers - New!
by JayWalkerLeo - 10/21/09 9:16 AM
Does anyone know if it is possible to take the power unit out of a set of powered pc speakers and put it  into a set of basic hi-fi speakers. The reason is the left speaker of the pc set does not work properly but all the amp bits work.
I have a pair of 20 (10+10) watt hi-fi speakers nothing special at all, but I wanted to know if i could swap the amp bits with all the cables from the pc set to the hi-fi pair without too many adverse affects.
Any help or advice is most welcome
jeff-o7 years ago
Yep, go for it!
skay2 jeff-o5 years ago
my borrowed pc external speakers are lousyy, , but how can i make a new setup/ basically how do i add the a/c power source. if i have a power supply, speakers, cable, can i make my own using better speakers? no not 200 watters, just for fun and using some low wattage quality speakers that havent been slammed on the ground like the ones i am 'borrowing' now. how to add he 'amp'/ for pc or mp3 player use..
i usually plug into my hifi system but it is in the other room.
jeff-o skay25 years ago
If you have experience with electronics you could build an amp for your speakers. If you've never touched a soldering iron (and don't want to now) then maybe you could find a cheap amp on craigslist or kijiji. You may even find one for free - I just scored an amp and two 3-way speakers for free on garbage day from the neighbour's curb.
Re-design7 years ago
Should work just fine.
