Address LEDs on a LOL shield help... please?
A couple of the tutorials use the following arrays... http://code.google.com/p/lolshield/downloads/list
I spent a couple hours trying to help out a friend and could not dumb the code down to address individual LEDs using the understood matrix below...
uint16_t BitMap[][9] PROGMEM = {
{1, 0, 0, 0, 0, 0, 0, 0, 0},
{3, 1, 0, 0, 0, 0, 0, 0, 0},
{7, 3, 1, 0, 0, 0, 0, 0, 0},
{15, 7, 3, 1, 0, 0, 0, 0, 0},
{31, 15, 7, 3, 1, 0, 0, 0, 0},
{63, 31, 15, 7, 3, 1, 0, 0, 0},
{127, 63, 31, 15, 7, 3, 1, 0, 0},
{255, 127, 63, 31, 15, 7, 3, 1, 0},
later in the code they use the following to 'fetch' the lines...
for(line = 0; line < 9; line++)       {
        data = pgm_read_word_near (&BitMap[frame][line]);   // fetch data from program memory
When I try to hi-jack the above line and use my 'own' numbers:
data = pgm_read_word_near (&BitMap[frame[1][3]);... it does not function..
I'm just trying to call out individual LEDs in response to external sensors and turn them ON and OFF with delays and such... any help breaking down this code? I understand the matrix but can't seem to call it out... thanks!
HERE is the sample code:
#include <avr/pgmspace.h>  //This is in the Arduino library
int blinkdelay = 75; //This basically controls brightness. Lower is dimmer
int runspeed = 20;   //smaller = faster
int pin13 =13;
int pin12 =12;
int pin11 =11;
int pin10 =10;
int pin09 =9;
int pin08 =8;
int pin07 =7;
int pin06 =6;
int pin05 =5;
int pin04 =4;
int pin03 =3;
int pin02 =2;
const int pins[] = {
  pin13,pin12,pin11,pin10,pin09,pin08,pin07,pin06,pin05,pin04,pin03,pin02};
const int ledMap[126][2] ={
{pin13, pin05},{pin13, pin06},{pin13, pin07},{pin13, pin08},{pin13, pin09},{pin13, pin10},{pin13, pin11},{pin13, pin12},{pin13, pin04},{pin04, pin13},{pin13, pin03},{pin03, pin13},{pin13, pin02},{pin02, pin13},
{pin12, pin05},{pin12, pin06},{pin12, pin07},{pin12, pin08},{pin12, pin09},{pin12, pin10},{pin12, pin11},{pin12, pin13},{pin12, pin04},{pin04, pin12},{pin12, pin03},{pin03, pin12},{pin12, pin02},{pin02, pin12},
{pin11, pin05},{pin11, pin06},{pin11, pin07},{pin11, pin08},{pin11, pin09},{pin11, pin10},{pin11, pin12},{pin11, pin13},{pin11, pin04},{pin04, pin11},{pin11, pin03},{pin03, pin11},{pin11, pin02},{pin02, pin11},
{pin10, pin05},{pin10, pin06},{pin10, pin07},{pin10, pin08},{pin10, pin09},{pin10, pin11},{pin10, pin12},{pin10, pin13},{pin10, pin04},{pin04, pin10},{pin10, pin03},{pin03, pin10},{pin10, pin02},{pin02, pin10},
{pin09, pin05},{pin09, pin06},{pin09, pin07},{pin09, pin08},{pin09, pin10},{pin09, pin11},{pin09, pin12},{pin09, pin13},{pin09, pin04},{pin04, pin09},{pin09, pin03},{pin03, pin09},{pin09, pin02},{pin02, pin09},
{pin08, pin05},{pin08, pin06},{pin08, pin07},{pin08, pin09},{pin08, pin10},{pin08, pin11},{pin08, pin12},{pin08, pin13},{pin08, pin04},{pin04, pin08},{pin08, pin03},{pin03, pin08},{pin08, pin02},{pin02, pin08},
{pin07, pin05},{pin07, pin06},{pin07, pin08},{pin07, pin09},{pin07, pin10},{pin07, pin11},{pin07, pin12},{pin07, pin13},{pin07, pin04},{pin04, pin07},{pin07, pin03},{pin03, pin07},{pin07, pin02},{pin02, pin07},
{pin06, pin05},{pin06, pin07},{pin06, pin08},{pin06, pin09},{pin06, pin10},{pin06, pin11},{pin06, pin12},{pin06, pin13},{pin06, pin04},{pin04, pin06},{pin06, pin03},{pin03, pin06},{pin06, pin02},{pin02, pin06},
{pin05, pin06},{pin05, pin07},{pin05, pin08},{pin05, pin09},{pin05, pin10},{pin05, pin11},{pin05, pin12},{pin05, pin13},{pin05, pin04},{pin04, pin05},{pin05, pin03},{pin03, pin05},{pin05, pin02},{pin02, pin05}
{511, 255, 127, 63, 31, 15, 7, 3, 1},
{1023, 511, 255, 127, 63, 31, 15, 7, 3},
{2047, 1023, 511, 255, 127, 63, 31, 15, 7},
{4095, 2047, 1023, 511, 255, 127, 63, 31, 15},
{8191, 4095, 2047, 1023, 511, 255, 127, 63, 31},
{16383, 8191, 4095, 2047, 1023, 511, 255, 127, 63},
{16383, 16383, 8191, 4095, 2047, 1023, 511, 255, 127},
{16383, 16383, 16383, 8191, 4095, 2047, 1023, 511, 255},
{16383, 16383, 16383, 16383, 8191, 4095, 2047, 1023, 511},
{16383, 16383, 16383, 16383, 16383, 8191, 4095, 2047, 1023},
{16383, 16383, 16383, 16383, 16383, 16383, 8191, 4095, 2047},
{16383, 16383, 16383, 16383, 16383, 16383, 16383, 8191, 4095},
{16383, 16383, 16383, 16383, 16383, 16383, 16383, 16383, 8191},
{16383, 16383, 16383, 16383, 16383, 16383, 16383, 16383, 16383},
{16382, 16383, 16383, 16383, 16383, 16383, 16383, 16383, 16383},
{16380, 16382, 16383, 16383, 16383, 16383, 16383, 16383, 16383},
{16376, 16380, 16382, 16383, 16383, 16383, 16383, 16383, 16383},
{16368, 16376, 16380, 16382, 16383, 16383, 16383, 16383, 16383},
{16352, 16368, 16376, 16380, 16382, 16383, 16383, 16383, 16383},
{16320, 16352, 16368, 16376, 16380, 16382, 16383, 16383, 16383},
{16256, 16320, 16352, 16368, 16376, 16380, 16382, 16383, 16383},
{16128, 16256, 16320, 16352, 16368, 16376, 16380, 16382, 16383},
{15872, 16128, 16256, 16320, 16352, 16368, 16376, 16380, 16382},
{15360, 15872, 16128, 16256, 16320, 16352, 16368, 16376, 16380},
{14336, 15360, 15872, 16128, 16256, 16320, 16352, 16368, 16376},
{12288, 14336, 15360, 15872, 16128, 16256, 16320, 16352, 16368},
{8192, 12288, 14336, 15360, 15872, 16128, 16256, 16320, 16352},
{0, 8192, 12288, 14336, 15360, 15872, 16128, 16256, 16320},
{0, 0, 8192, 12288, 14336, 15360, 15872, 16128, 16256},
{0, 0, 0, 8192, 12288, 14336, 15360, 15872, 16128},
{0, 0, 0, 0, 8192, 12288, 14336, 15360, 15872},
{0, 0, 0, 0, 0, 8192, 12288, 14336, 15360},
{0, 0, 0, 0, 0, 0, 8192, 12288, 14336},
{0, 0, 0, 0, 0, 0, 0, 8192, 12288},
{0, 0, 0, 0, 0, 0, 0, 0, 8192},
{0, 0, 0, 0, 0, 0, 0, 0, 0},
{18000}
void setup() {
  blinkall(2); // useful for testing
void loop() {
  DisplayBitMap();
void turnon(int led) {
  int pospin = ledMap[led][0];
  int negpin = ledMap[led][1];
  pinMode (pospin, OUTPUT);
  pinMode (negpin, OUTPUT);
  digitalWrite (pospin, HIGH);
  digitalWrite (negpin, LOW);
void alloff() {
  DDRD = B00000010;
  DDRB = B00000000;
void DisplayBitMap()
  boolean run=true;
  byte frame = 0;
  byte line = 0;
  unsigned long data;
  while(run == true) {
    for(int i = 0; i < runspeed; i++)     {
        if (data==18000){
          run=false;
        else for (byte led=0; led<14; ++led) {
          if (data & (1<<led)) {
            turnon((line*14)+led);
            delayMicroseconds(blinkdelay);
            alloff();
          else {
    } frame++;
void blinkall(int numblink) {
  alloff();
  for(int n = 0;n < numblink;n++)   {
      for(int j = 0; j < 126; j++)       {
        turnon(j);
        alloff();
    delay(500);
Picture of Address LEDs on a LOL shield help... please?
giseburt4 years ago
This line is key:
It fetches one line (14 LEDs wide) from one "frame" (or full display of LEDs) at a time. This line is encoded as bits in a 16bit integer.
If you wanted to set the display to something semi-static, instead of an animation, then you need to provide that data directly, then let it loop over the rows (line) and columns (led).
You could/should also get rid of the while(run==true) and if data=18000, since those handle all of the frames.
At the top, instead of BitMap, you would have:
uint16_t screen_data[9] = {0,0,0,0,0,0,0,0,0};
I don't have one of these, and I'm answering from my phone, so this code might not work directly. Specifically, X and Y might be flipped.)
Setting a led on:
screen_data[y] |= 1<<x; // sets the x'th bit on the y'th row
Turning an led off:
screen_data[y] &= ~(1<<x); // clears the x'th bit on the y'th row
And the data = progmem_... Becomes simply:
data = screen_data[line];
Don't forget to either pull the while loop or set run = false or it'll infinite loop.
-Rob
maewert4 years ago
I think your problem is that you 'broke' the method the code uses by avoiding the variables.  The code uses the frame and the line variables but you avoided using them by attempting to use [1][3] indices.  (It also appears as though you were trying to treat 'frame' as an array.
Later in the code the LEDs are actually turned on using these variables: 'turnon((line*14)+led);'
try changing the code and use "frame=1" and 'line=3'
(you'll need to change the for loop to no longer use 'line')
Sorry, I can't tell you specifically what you did wrong since you did not include the bad code.
Best Wishes
hydronics (author)  maewert4 years ago
I think this is the wrong code because it assumes a discrete # of patterns; such as, a letters 'A'.'B'. 'C'... where my friend is trying to light up pre-assigned LEDs based on events.. and the events may be happening at the same time... so how do you add say add the arrays A and B?
maybe I should be using the LEDsign command.. I checked it out in the charliplexing library and it didn't make a lot of sense...
if (data==18000){
run=false;
//This is where the bit-shifting happens to pull out
//each LED from a row. If the bit is 1, then the LED
//is turned on, otherwise it is turned off.
if (data & (1< LedSign::Set(led, line, 1);
else {
LedSign::Set(led, line, 0);
Yes, I see what you mean...I did leave out the 'turnon' command... It still amazes me how complex this little board is but I suppose its just the same old learning curve or learning wall I'm looking at...
thanks, for the quick reply. -tom
