loading
Adjusting pH levels?
So, I am doing a science fair project about what  pH level is best for sea monkeys and what happens with the other levels.  Dies anyone know how to  adjust the pH levels easily in such a small amount of water??
Burf3 years ago
Do some research to determine proper pH levels for your aquarium. Go to a well supplied dealer and get a pH test kit and the appropriate buffers. Set up at least two tanks, using one as a control and the second as the test tank.
Carefully observe, monitor and record everything you do, compile your data and write up the results and your conclusions.
+1. Learn ALL about buffers FIRST.
+1. Ohh... Buffers... I hate them x( But seriously, you may not do a good research project if you can't explain how to change pH levels.
+1
