Alternate power supply for an old laptop?
For those who it may concern, thanks if you can help. Got an Toshiba 460CDT laptop that has everything inside (HDD, RAM, battery, etc), but there is one thing that concern me, the power supply. I didn't came with it, being super cheap (3$), so now I'm in need for a 15V 3A power supply which I don't have. So for my question, would another power supply, like a wall wart, would work with this old laptop? Is there a difference using a wall wart or a laptop power supply to power a laptop? Would any power supply, being 15V 3A or 10.8V recharge the 10.8V 3600mAh battery even if its a few units off? And say if the battery was dead when I do find a power supply, would this old laptop still use the power supply to power up the computer without the battery?
gmxx8 years ago
you computer should be able to startup without the battery.
A laptop power supply and a walll wart are pretty much the same thing.. (Like a hp computer and a dell computer, They do the same thing, but look different)
What you need to look for is a power supply that is
15-18v (the extra 3 volts should be fine. Don't go more or less.)
3A or more. (When looking at power units, it is important to have a power supply that can give enough current. if you go lesss than 3a, then you risk blowing something up. amperage just tells how many 15volts it can give. Anything over 3a will be fine, the laptop will take what it needs. I wouldnt go over by too much though.)'
Match what the laptop power brick would have given, not what the battery says. you need the extra volts, and amps to charge... for example, for some of the batteries i use (12v /20a) we use 13.8v chargers.
Just an addition to the best answer above. A lot of laptops now are using nearly identical power bricks. Especially the generic brands. All five of the laptops in my home have a power brick with the same jack and the same voltages/amperages. So, what I'm saying is... you might be able to borrow/buy an extra one from a friend, the computer shop, craigslist, etc. The other thing I wanted to mention was that your computer might NOT start up with out a battery. I'm not 100% certain with that model. Some do, some don't. My gateway and toshiba's don't, my sony and acer's do. However, if you still have the dead battery, just leave it in and it will work on AC.
