Alternative power sources for a coilgun?
I was wondering if there was any other method to power the firing coil of a single stage coilgun without using capacitors. My main reasoning is to try to reduce recharge time, and to also avoid making massive groups of capacitors and finding a place to put them.
It needs to be able to be powered by some form of battery, meaning I could connect voltage to this circuit (1.2 volts up to 12 volts. I'm not picky) and shouldn't consist of hard to find components.
I'm not looking for the greatest efficiency in the world, just making a step (okay, maybe a stomp) toward building a 'capless coilgun'.
6
answers
Answer it!
It's like the cheap, good, fast analogy -- but with power its voltage, amperage, and time (power, in a sense). A coil gun is putting a HUGE impulse on an object for a very short (less than milliseconds) period of time. Batteries have lots of power but not 'quickly available' power. Capacitors don't have much comparatively, but they do put it out almost instantly.
Recharge time is 'slow' because you're not putting power into the capacitor quickly enough, not because the cap charges slow. Within reason, your problem can be solved with a bigger power supply.
Lastly, lots of people take for granted how much actual energy is stored in gasoline or gunpowder...even sugar has HUGE power compared to 'capacitors'.
The flyback would take 'average' voltage and high current and turn it into low current high voltage.
Capacitors would take that flyback voltage (high voltage, low amperage) and store it up for a while, so it has a high overall energy (high voltage high power). THAT capacitor energy can be released in a fraction of a second (while the object is still in the barrel). THAT will make a good coil gun.
If you tried to fire with just the transformer, you'd get enough voltage, but not enough current.
