Amplify FM transmitter range?
http://www.lucidscience.com//projects/Basic%20Spy%20Transmitter/8.jpg
This all relates to the picture linked to above
I was not sure if I could put an amplifier before the antenna to boost the signal going to the antenna extending the range anyone know for sure it seems to make sense
ARJOON6 years ago
is there anyone who can help in there also. just for experimenting. will put it in a diy competition. my only problem is to amplify the signal
NachoMahma7 years ago
. I think you are looking for a linear amplifier.
Algag (author)  NachoMahma6 years ago
ya i just wasnt sure about if it would work...oh btw i like the comment on the Archimedes screw question
"What part are you having problems with? . You can't get much simpler than an Archimedes Screw. It's just a screw in a tube."
I actually put it on my FB page :P
rickharris7 years ago
A correctly matched antenna (length). used the higher supply voltage, use the most efficient circuit you can find and this may not be it. IF you intend to power from the mains and a simple wall wart is a good hiding place that most people would ignore, then consider using the mains wiring to carry the signal this can travel a long way and only requires a receiver plugged into the same phase of the supply to pick it up.
Oh and just a warning, people who listen in at doors and otherwise rarely hear anything good about themselves so be prepared.
Algag (author)  rickharris6 years ago
:D ya i was actually thinking more along the lines of simple walkie talkie style communicators :p
orksecurity7 years ago
Note too that boosting the power of a transmitter risks violating FCC regulations. Generally not a great idea unless you have a ham license and are working in the bands specifically allocated for experimentation.
Algag (author)  orksecurity7 years ago
ya i know that (that was not meant snarky or mean) but i am not meaning any serious radio station etc i just mean room to room, and you never answered directly yes it is possible just not neccesarily legally or no not gonna work
+1
