loading
Any recommendations on how to increase the crappy audio volume on my EEE PC?
Trying to watch streaming TV through my Eee PC while I'm on the road is infuriating because I can't hear the audio even with headphones and the volume cranked all the way to 11. Time/talent aren't on my side so I'm not sure I'd be able to kludge together some of the projects here. Thx, Wudjor
As a powerful
video editor and converter, Avdshare Video Converter will easily increase the
sound volume of Video or Audio with simple settings. Here is the easy guide at
http://www.avdshare.com/increase-audio-volume-of-mp4-mp3-wav-avi-wmv-mkv-vob-mpg
You may try iDealshare VideoGo to increase the volume of a video or audio files at How to Increase Video Audio Volume in MOV, MP3, MP4, WAV, AVI?
Working as an Audio Volume Booster, iDealshare VideoGo
can easily boost sound volume for almost all kinds of audio file like
increase MP3 volume, increase WAV volume, increase FLAC volume,
increase AAC volume, increase AC3 volume, M4A, WMA, AU, DTS, AIFF,
OGG, MP2, APE, OPUS, CAF, VOC, etc.
Working as a Video
Volume Booster, iDealshare VideoGo helps you raise audio volume for
all video files like increase MP4 volume, increase MOV volume,
increase AVI volume, WMV, FLV, AVCHD, MKV, MXF, WebM, SWF, OGV, 3GP,
ASF, RMVB, etc.
iDealshare VideoGo also has a feature of
increase sound volume as well as change the source file format like
convert the source audio or video files to other more compatible audio
or video formats.
Step by step gudie at
http://www.idealshare.net/video-converter/video-au...
Sometimes even with the volume in the highest level, it still sounds
very slight. In this case, I usually increase the sound volume by
Faasoft Volume Booster. With it, you can adjust audio or video volume as
your desire.
Here is a quick guide on how to increase volume of video or audio with this tool at: http://www.faasoft.com/article...
Hope it is what you are looking for.
Carl Meyer3 years ago
Some encountered the same issue with you. I recommend you a blogger which is professional to solve the problem at:http://audioconverters.blogspot.com/2011/04/how-to-increase-audio-volume-video-avi.html
Hope it can help you!
You may refer to the following step by step guide on How to Increase Audio Volume in MP3, MP4, WAV, WMA, WMV, MKV, VOB, MPG at http://www.idealshare.net/video-converter/video-audio-volume-booster.html
This guide can easily help:
Increase audio volume of all popular audio formats like increase MP3 volume, increase WAV volume, increase WMA volume, or increase sound volume in AC3, FLAC, M4A, VOC, QCP, AMR, AWB, OGG, CAF, AIFF, RA, AU, APE, and etc
Boost the sound volume from video files like increase MP4 volume, increase AVI volume, boost the sound volume from other video formats including WMV, MOV, MPG, FLV, 3GP, VOB, MKV, ASF, RMVB, AVCHD, MXF, DV, and etc
Extract audio from video and then convert to audio format as well as increase the audio volume
Increase audio volume as well as convert to other audio formats
Increase video volume as well as convert to other video formats
Remove audio from video files like MP4, AVI, WMV, MKV, VOB, FLV, MPG, 3GP, MOV and etc
ojutan6 years ago
in the realtek audio manager there is an equalizer. Setting all of them to max and clicking on the "on" button will increase the volume dramatically.... unfortunately the algorithm behind that is somehow cheap and on my sennheiser hifi headphones you hear audio artifacts especially when playing DVD
For Linix there are some patches for the audio mixer but it seams in Windows it's app based.... I'll give the Haali media splitter a try because it is able to send all media streams through external filters, and if there is a filter "volume x4" I'll get it, and if it doesn't exist I'll make one
underdesign7 years ago
I have a EEE PC as well, and I know what you're talking about.  Since the speakers are on the bottom, I find tilting the laptop so the front of the keyboard is off the ground by an inch or so really makes a difference.  It doesn't even affect your view, but it does make typing funny.  You can also wedge a reflector under the laptop to bounce the audio forward (vs. down).
KahlZun7 years ago
Hack some old earbuds/headphones, make a small low-power amp, hook up to a speaker.
See for similar:
https://www.instructables.com/id/Headphone-amplifier/
Joe Martin7 years ago
What model is it, I'm guess you might be running linux as it does not have the realtek control panel for dolby sound room, If your on xp have a look in control panel, Realtec somthing (The icon is of a red speaker) and make sure for sound effect you have it on none as if its on padded room or hallway I find the volume always seems decresed.
plumber_bob7 years ago
We actually have a similar problem as we like to watch tv episodes on mrs_bobs laptop and the volume doesn't get up enough to hear unless you're right in front of the laptop. I found a small cheap speakers with an amplifier setup, in my junk pile. So now I have two volume controls. I think that you can find something similar, and fairly cheap. Yard sales might be a source. Hope this gives you an idea.
