Anyone got some creative fencing ideas?
11
answers
Answer it!
Before you build anything that actually involves any effort you could try this:
I made a flower bed that is 18 inches from the back gate and directly in front of it. The dogs always run frantically from the gate over this patch.
After making the flower bed I simply pushed some twigs and branches into the soil in front and behind, (Some of them both ends to make an arch.) It took about three minutes.
One dog is a massive labrador and the other is a terrier that will run through anything to get to what it wants.
Anyhoo, it works; they run; they hesitate; they go around.
It may not work for you but its worth a go; and if it does you have an easy solution.
Good Luck
FOH
well cider bottles they were more fun to drink.
dig a trench cut the top off and bottom of the bottles.
insert in trench fill with earth insert next bottle and fill and so on.
if dirt poor use top,s of bottles as nuts and bolts or duct tape.
1 was to use pallets I found .Put standing next to each other and nail together. Then attach end pieces on 90 deg and do the same on other side if you need to encircle . I was also told about using guttering that is attached to fencing at 3-4 foot height . It works quite well for herb gardens and also inhibits weeds.That would be for like next time. Hope this helps you out . : D
Perchance vary the angles they make to the ground to give it some artistic appeal/pattern.
Then you can use pipe or rebar at what ever intervals you need to fit your dogs.
Check out the pallet projects on this site for some ideas for pulling pallets apart- ( I am currently helping my kids build a treehouse from pallets and I would say the most important tool to use for pulling pallets apart is Patience! )
