Anyone know of an adhesive for Lego's that can be undone by say, soaking in water or something else?
I've just been thinking Lego's would be more useful if the bond was stronger.
acidbass7 years ago
super glue a mixture of flour and water Elmer glue tiebond 3 poly and the car stores sell a plastic to plastic adhesive that pries apart it is used for the emblems on the cars
DREWSR (author)  acidbass7 years ago
I never expected to actually get an answer to this question. Thank you for taking the time!
How abuut using a "composite" and gluing paper to the inside of the model with PVA ? That should all soak away in warm water, and it will be a lot stronger than just PVA/Elmers
caarntedd7 years ago
Polyurethane sealant. Sticks good, peels off plastics easy.
Kiteman7 years ago
Stronger?
What are you trying to build?
He must have seen this video.
lemonie7 years ago
Epoxy will "pick-off", the plastic is quite resistant to it - it doesn't really "stick" it more "adheres".
L
rickharris7 years ago
PVA -Eelmers glue - isn't water proof although it may need soaking to loosen, Super glue also gives way when soaked.
Super glue
NachoMahma7 years ago
Elmer's Glue All* will dissolve in warm water, but it' may not stick very well to the slick plastic used for Legos.
* It did last time I used it, but that was about 15 years ago and the formula may have changed.
nickodemus7 years ago
I don't know of anything that would be dissolvable in water...
I'm fairly sure most PVC glues were meant to be water tight. So if you don't mind it being permanent, try using pvc glue. If you want to see how well it would work, just test it on some lesser pieces that you wouldn't mind losing.
