loading
Application: Sequential Search in asm ?
hi
This question and the code works
But the problem is that it when u the number not found the prog print both msg
help me
thank you
noor.
_____________________________________________________----
write a program that asks the user to enter an integer
       By writing
Enter the Number ----------------------------- :
And then perform the  Linear Search for the user entered number in an Integer Array given below :
intArray    SDWORD   -18,40,5,-11,66,4,-7,10,16
If the number is found , it displays ,
Yes the numbers exists in the list.
If the number is not found then it  displays.
The number is not found in the list.
TITLE sum of the integer
.686
.MODEL FLAT,STDCALL
.STACK
INCLUDE Irvine32.inc
.data
a sdword ?
str1 byte "enter the number   :  ",0
str2 byte "Yes the numbers exists in the list",0
str3 BYTE "The number is not found in the list",0
intarray sdword -18,40,5,-11,66,4,-7,10,16
.CODE
MAIN PROC
mov edx,offset str1
call writestring
call ReadInt
mov a,eax
call Search
exit
main endp
Searchproc proc uses ecx
jne notfound
mov esi,offset intarray
mov ecx,lengthof intarray
l1:
cmp[esi],eax
je found
add esi,4
loop l1
jmp notfound
notfound:
mov edx,offset str3
call writestring
;call writeint
call crlf
found:
mov edx,offset str2
call writestring
call crlf
ret
exit
Searchendp
end main
a7la nono (author) 5 years ago
this answer but with out the processor
.686
.MODEL FLAT,STDCALL
.STACK
.data
a sdword ?
list",0
.CODE
MAIN PROC
mov edx,offset str1
call writestring
call ReadInt
mov a,eax
l1:
cmp[esi],eax
je found
add esi,4
loop l1
jmp notfound
found:
mov edx,offset str2
call writestring
call crlf
jmp q
notfound:
mov edx,offset str3
call writestring
;call writeint
call crlf
exit
q:
call crlf
exit
main endp
end main
