Arduino Code?
int redPin = 9;
int greenPin = 10;
int bluePin = 11;
int buzzerPin = 7;
int potPin = 1;
int sensorPin = 0;
long red = 0xFF0000;
long green = 0x00FF00;
long blue = 0x000080;
int band = 10;
// adjust for sensitivity
void setup()
  pinMode(potPin, INPUT);
  pinMode(sensorPin, INPUT);
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  pinMode(buzzerPin, OUTPUT);
void loop()
    int gsr = analogRead(sensorPin);
    int pot = analogRead(potPin);
    if (gsr > pot + band)
        setColor(red);
        beep();
    else if (gsr > 16;
    int green = (rgb >> 8) & 0xFF;
    int blue = rgb & 0xFF;
    analogWrite(redPin, red);
    analogWrite(greenPin, green);
    analogWrite(bluePin, blue);
void beep()
    for (int i=0; i<1000; i++)
        digitalWrite(buzzerPin, HIGH);
        delayMicroseconds(100);
        digitalWrite(buzzerPin, LOW);
The code does not compile properliy it says steColour was not defined in the scope.Its a lie detector code.
Bot13985 years ago
int redPin = 9;
int greenPin = 10;
int bluePin = 11;
int buzzerPin = 7;
int potPin = 1;
int sensorPin = 0;
int band = 15;
void setup()
void loop()
setColor(red);
beep();
else if (gsr < pot - band)
setColor(blue);
else
setColor(green);
void setColor(long rgb)
int red = rgb >> 16;
void beep()
I modified the code a little now it compiles SUCCESSFULLY
+1.
When working with incredibly simple projects like this I really like to use 3 different byte values, or an array or bytes [R,G,B] rather than shifted concatenated long variables -- if someone doesn't grasp binary math they have a real tough time with that one!
Good fix though!
The error is telling you that the places where you have setColor(); in the code have not been defined. The IDE doesn't know if that is suppose to be a variable, a function, or whatever its suppose to be. You have a function defined for beep(); your just missing your setColor(); function.
