Arduino Uno TV B Gone code error ?
I just got an arduino (the arduino is a fake off ebay, didnt know at the time.) It runs off of a ATMEGA8A-PU. I have built a few projects that work but now following this tutorial:
http://www.righto.com/2010/11/improved-arduino-tv-b-gone.html
Not sure if im just missing something or what I've done wrong but the compiler keeps giving me the error of:
TVB.ino: In function 'void xmitCodeElement(uint16_t, uint16_t, uint8_t)':
TVB:92: error: 'TCCR2A' was not declared in this scope
TVB:92: error: 'COM2A0' was not declared in this scope
TVB:92: error: 'COM2B1' was not declared in this scope
TVB:93: error: 'TCCR2B' was not declared in this scope
TVB:93: error: 'WGM22' was not declared in this scope
TVB:106: error: 'TCCR2A' was not declared in this scope
TVB:107: error: 'TCCR2B' was not declared in this scope
TVB.ino: In function 'void setup()':
TVB:191: error: 'TCCR2A' was not declared in this scope
TVB:192: error: 'TCCR2B' was not declared in this scope
TVB.ino: In function 'void sendAllCodes()':
TVB:274: error: 'OCR2A' was not declared in this scope
TVB:275: error: 'OCR2B' was not declared in this scope
That's because your chip doesn't have the resources that the library needs. The board is not an "optiboot 8", that's the name of the bootloader on the chip.
...and here I mean the chip specific library you need.
Try compiling the code against the "Arduino NG or older" board.
Aaamazzara (author)  steveastrouk3 years ago
same error still.
might have to get a really old copy of the arduino suite then. What are you using?
These kinds of errors tend to happen when the library is missing. If there is a library accociated with this project make sure you have it in the right folder.
Aaamazzara (author)  mpilchfamily3 years ago
I downloaded the only download provided and there was nothing said about a library. In the arduino sketch if I change the board to Arduino Uno then it compiles fine but once I switch it to the Optiboot8 (the board type it is apperently) it gets the errors again.
