Arduino battery 9.6V 650mAh. Help?
I have alot of rc plane Ni-MH recharagables that I dont have a use for since my reciver blew up. Can I run my arduino deumonlative on these batterys they are 9.6V and 650mAh.
Also I wold like to know how many mA can I draw from the arduinos 5V supply.
Thanks for any help, David.
jmsaltzman6 years ago
You can draw 500mA from the Arduino's 5V supply, 2.5W of power, but since it uses a low dropout regulator, it will dissipate the remaining ((9V - 5.5V) * 500mA) 1.75W into heat. Give or take.
So it will get pretty warm even if ventilated.
If you need that much current, you could instead use transistors switched by just a few mA of current from the Arduino's output pins, as in this Instructable.
David97 (author) 6 years ago
I think that I can olny draw 500 mAh from the arduino otherwise the fuse kicks in.
Pulling that much from a 9V source on an arduino board is going to make somehting very hot.
You can only draw mA, not mAh
