Arduino yellow drummer robot?
I was looking at building a yellow drummer robot that I saw in Make 25. I don't have a Picaxe, the problem is that I have seen pictuures and videos of people that have used arduino but no detailed instructions. Can anyone give me a link to instructions or  give me tips. The best help I have had so far is the code. But how do I connect it up?
(I have a arduino deumonlatave, but it should still work).
// Yellow Drum Machine Program for Arduino Uno
// setup pins and variables for SRF05 sonar device
int echoPin = 12;                               // SRF05 echo pin (digital 12)
int initPin = 13;                               // SRF05 trigger pin (digital 13)
unsigned long pulseTime = 0;                    // stores the pulse in Micro Seconds
unsigned long distance = 0;                     // variable for storing the distance (cm)
// setup pins for drivetrain motors
int DCMotor1Drive = 10;                         // DCMotor1 Drive Pin (PWM 3)
int DCMotor1Reverse = 3;                        // DCMotor1 Reverse Pin (PWM 10)
int DCMotor2Drive = 9;                          // DCMotor2 Drive Pin (PWM 6)
int DCMotor2Reverse = 6;                        // DCMotor2 Reverse Pin (PWM 9)
// setup pins for sonar pivot pager
int SensorPagerRight = 11;                        // SensorPager rotate right Pin (digital #)
int SensorPagerLeft = 5;                         // SensorPager rotate left Pin (digital #)
// setup pins for drumstick pagers
int Pager1 = 8;                           // Pager1 rotate forward Pin (digital #)
int Pager2 = 2;                         // Pager1 rotate reverse Pin (digital #)
int Pager3 = 1;
int speed = 0;
int averageDistance = 0;                        // stores the average distance value
int mode = 0;
// Function for sonar reader
int readsonar() {
  // variables to take x number of readings and then average them
  // to remove the jitter/noise from the SRF05 sonar readings
  const int numOfReadings = 10;                   // number of readings to take/ items in the array
  int total = 0;                                  // stores the cumlative total
  // create array loop to iterate over every item in the array
  for (int i = 0; i < numOfReadings; i++) {
    // Trigger sonar to take reading
    digitalWrite(initPin, HIGH);                    // send 10 microsecond pulse
    delayMicroseconds(10);                          // wait 10 microseconds before turning off
    digitalWrite(initPin, LOW);                     // stop sending the pulse
    // Read sonar distance
    pulseTime = pulseIn(echoPin, HIGH);             // Look for a return pulse, it should be high as the pulse goes low-high-low
    distance = pulseTime/58;                        // Distance = pulse time / 58 to convert to cm.
    total= total + distance;                        // add the reading to the total
return total / numOfReadings;
// Drivetrain movement command functions
  /* Drivetrain Forward */
  int goforward(int speed) {
    analogWrite(DCMotor1Reverse, 0);
    analogWrite(DCMotor1Drive, speed);
    analogWrite(DCMotor2Reverse, 0);
    analogWrite(DCMotor2Drive, speed);
  /* Drivetrain Reverse */
  int goreverse(int speed) {
    analogWrite(DCMotor1Reverse, speed);
    analogWrite(DCMotor1Drive, 0);
    analogWrite(DCMotor2Reverse, speed);
    analogWrite(DCMotor2Drive, 0);
  /* Drivetrain Turn Right */
  int goright(int speed) {
  /* Drivetrain Turn Left full speed*/
  int goleft(int speed) {
  /*Drivetrain turn around*/
  int turnaround(int speed) {
     analogWrite(DCMotor1Drive, 255);
     analogWrite(DCMotor2Reverse, 255);
  /* Pager Pulse functions */
  int rightstick() {
    digitalWrite(Pager1, 0);
    delay(200);
    digitalWrite(Pager1, 1);
  int leftstick() {
    digitalWrite(Pager2, 1);
    delay(200);
    digitalWrite(Pager2, 0);
  int tailstick() {
    digitalWrite(Pager3, 1);
    delay(200);
    digitalWrite(Pager3, 0);
//Operational Modes
  //Target Seeking Mode
 int findtarget() {
   int Center = readsonar();
   if (Center > 50)
     goforward(255); //Go forward!
   else
     mode = 1; //
  //Fine-Tune Targeting Mode
 int lockontarget() {
    // Reading and moving the sonar
    digitalWrite (SensorPagerLeft, 1);
    digitalWrite (SensorPagerRight, 0);
    delay (500);
    int Left = readsonar();
    digitalWrite (SensorPagerLeft, 0);
    digitalWrite (SensorPagerRight, 1);
    delay (500);
    int Right = readsonar();
    delay (500);
    //Speed and Direction Control
     if ((Center < Right) && (Center < Left)) {
       if (Center > 50)
       else if (Center > 7)
         goforward(128); //
       else
         mode = 2;
     else if ((Right < Center) && (Right < Left)) {
       if (Right > 50)
         goright(255); //Go forward!
       else if (Right > 7)
         goright(128); //
       else
         mode = 2;
     else if ((Left < Center) && (Left < Right)) {
       if (Left > 50)
         goleft(255); //Go forward!
       else if (Left > 7)
         goleft(128); //
       else
         mode = 2;
//LET THE BEAT DROP!
int makesomenoise() {
   tailstick();
   rightstick();
   leftstick();
   delay (500);
   tailstick();
   rightstick();
   leftstick();
   delay (500);
   tailstick();
   rightstick();
   leftstick();
   delay (500);
   tailstick();
   tailstick();
   tailstick();
   tailstick();
   rightstick();
   leftstick();
   tailstick();
   rightstick();
   leftstick();
   delay (500);
   tailstick();
   rightstick();
   leftstick();
   delay (500);
   mode = 3;
   //Go Somewhere Else//
 int runaway()
   goreverse(255);
// setup
void setup() {
  pinMode(DCMotor1Drive, OUTPUT);                     // sets DCMotor1Drive as output
  pinMode(DCMotor1Reverse, OUTPUT);                   // sets DCMotor1Reverse as output
  pinMode(initPin, OUTPUT);                           // set init pin 13 as output
  pinMode(echoPin, INPUT);                            // set echo pin 12 as input
  pinMode(Pager1, OUTPUT);
  pinMode(Pager2, OUTPUT);
  pinMode(Pager3, OUTPUT);
 // initialize the serial port, lets you view the
 // distances being pinged if connected to computer
 //    Serial.begin(9600);
void loop()
  if (mode == 0)
    findtarget();
  else if (mode == 1)
    lockontarget();
  else if (mode == 2)
    makesomenoise();
    turnaround(255);
    mode = 0;
  // Serial.println(mode, DEC);         // print out the average distance to the debugg
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
