loading
Are Foam Cutting Fumes Toxic??
I've made a hot wire foam cutter but I'm wondering now if the fumes are cancerous/dangerous/toxic when you breathe them in. I've researched this myself a little but there are mixed answers and many others are unsure. Any answers?
seandogue7 months ago
Yes. Always Ventilate. Smoke need not be produced to create toxic fumes. If you can semll it, they're there.
Downunder35m7 months ago
What is there to be unsure about apart from the fact that you did not provide any details on the materials you want to cut.
Put simply: if it is dangerous or even toxic when it burns then the same is true when you cut it - there is a good reason why proper cutters always come with a proper fume extraction system...
+1
RampedUpDIY7 months ago
In short, yes the fumes made when cutting foam are harmful. However, how much they affect you depends on how much you are exposed. I always just set up a shop vac or fan beside my foam cutter to pull the fumes away from me.
iceng7 months ago
Iv been cutting Styrofoam 50 years. The best way to cut, is to adjust a massive wire (3/32" iron weld rod) to simply melt through NO+SMOKE and not burn the foam.. Occasionally I smoked some with a solder iron... I'm writing and alive married with grand kids and a lot of tin lead solder fumes too...
iceng iceng7 months ago
Sorry forgot the pictures click them to see the whole image..
styrofoamCutter.jpgTool1 round.bmpEdge-cut-LAYER4.JPGFirstcutting(25).JPGHotCurrent.JPG
rickharris7 months ago
Safety sheet for poly styrene
http://www.southlandpolymers.com/pdf/polysty/Denka...
I would avoid cutting at a temp that creates fumes.
Over all it can't be that hazardous as schools cut polystyrene foam all the time.
Yonatan247 months ago
How much?
Breathe as little as possible.
