Are there Dremel attachment(s) meant for removing or shaping solid aluminum?
First, I'll explain the background for my question.  I've been meaning to make a 1000 lumen Maglite (Jayrob from CandlePowerForums conceived the design-look it up, it's awesome).  I can get the heatsink from CPF vendors but they come with a 14.5mm diameter pedestal.  I want to reduce the diameter of the pedestal, ideally to less than 12.5mm in order to use a reflector with a smaller hole.
So, which Dremel rotary tool attachment(s) would be appropriate for removing and/or 'shaping' aluminum?  Any ideas, other suggestions, or musings?
Thanks.
Dec 30, 2011. 11:39 PMBurf says:
Use the steel cutting bits, they come in various configurations. Keep the bit and the piece being worked well lubricated with a light machine to help prevent the bit from clogging with the aluminum shavings. Check the bit frequently and clean out any particles stuck in the bit with a pin or small awl.
Take your time and don't get too aggressive when shaping the aluminum.
Dec 31, 2011. 12:00 AMiceng says:
+1
soft Al smears the metal bit or file.
Dec 31, 2011. 3:24 AMfrollard says:
I recall adding chalk to files to prevent the chaff from sticking too badly...similar couldn't hurt on the cutting tool.
Dec 31, 2011. 7:42 AMBurf says:
That should read "light machine oil".
Dec 31, 2011. 3:26 AMsteveastrouk says:
We find the best lubricant for aluminium cutting is a solution of clean engine oil and "white spirit"- which is a paint thinner.
Steve
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
