Battery memory effect: a thing of the past?
9
answers
Answer it!
I've actually seen battery heaters on a few surplus sites. They're described as leftovers from laptop battery manufacture. The few times I've ever dissected a rechargeable battery pack, I've never seen anything that looked like a heater.
I'm not sure how that would work in a laptop. I suppose they wouldn't actually work if the battery was too cold to function. I'm from Florida. I've never seen REAL cold. Or even snow. I can't say personally how the cold effects laptops. They may kick in when the battery decides the lower temperature limit is approaching. If they have heaters, that might explain part of the battery drain problem vs. a cell phone.
Either way, though I have to say the 'memory effect' isn't the same as it was with the ni-cads. Maybe there is something similar, but I've never seen it on the new ones. When we have bad notebook or tool batteries to scrap, I take out the cells. I check which one's take a charge and dump the rest in the recycle / scrap bins. Free batteries are a good thing. Every bad battery had at least one bad cell. with the ni-cads, nearly every cell would take a fraction of a charge or none. With these new one's they either charge all the way or the don't it seems like.
I've never noticed the thing about leaving it in the fridge. That makes sense though, because the chemical reactions inside would slow down. You would probably have to wait for it to warm up again before you use it. I'm going to check some of the manuals at work tomorrow and see if I can find that instruction. Thanks for the tip.
