loading
Best way to make a remote controlled device that goes up and down like a car antenna?
Just wondering, what's the best way about making a device that is sort of like a tripod, without the pan and tilt or left and right? just need the pole type device to go up and down like a car antenna?
Is it possible to control this via remote from like 100 - 200 feet away?
and possible to control height of the poles? (i'm guessing a switch)
 i was thinking poles will probably be PVC pipes or is there anything better to use?
thanks for your advice!
rickharris5 years ago
The antenna is simply a stiff wire wound round a drum - As the wire unwinds it goes up the inside of the hollow antenna pushing it up
zaronas5 years ago
well i dont know how high or what it is you are trying to lift but you could get a motor and wheel against your pvc pipe and the pipe would be in a casing and then run it up with the motor, you could also seal it in a case and raise it like a piston
jeppers113d (author) 5 years ago
i think i may have found the solution
http://servocity.com/html/heavy_duty_linear_servo__115__.html
thank you guys
How heavy is the load you want to lift, and how high ?
