Bio dust grinder?
I have seen this video on Youtube and was wondering if anyone new how to make this machine or any ideas. http://www.youtube.com/watch?v=wW2GC_wFkaM
Re-design4 years ago
Build your box out of 1/4' steel plate. Mount bearing and an axle in the middle. Mount 10 or 12 10" carbide table saw blades on the axle. Hook a 2 hp motor to the axle. mount a feed tube over the blades. Feed in wood as needed.
x3wayassassin (author)  Re-design4 years ago
how would i get all of them to be stationary so they don't spin when i turn the motor on? i thank you very much for your reply i have looked every place and asked everyone except here. your idea is very well appreciated.
I would use whats called a "dado stack". Those are blades that are made for taking large amounts of wood out at a time. You can key the blades to the shaft or just tighten them down with nuts on each side. My table saw is not keyed just thghtened by a nut. This method will create sawdust, YOu can then pack into pellets with another machine. To cut specific sizes it is going to be harder.
what does key the blades mean?
Keyways have to fit your blades. check this out
also how many teeth?
x3wayassassin (author)  x3wayassassin4 years ago
the material needs to be around a quarter of an inch in length if that helps at all.
