loading
Boost converter?
How to make boost converter that will convert 3.8 volts to 5 volts for my android????
iceng1 year ago
Is the yellow area where you want to put the boost converter ?
PavleP (author)  iceng1 year ago
I need it because I want to power OTG devices when I connect them and I need 5 volts for that.
iceng PavleP1 year ago
I understand you need 5 volts.
Where do you believe there is room for a mini boost parts....
Consider that the through hole parts can be reduced by 1/3 by using SMD parts and the electrolytic capacitors can be reduced 1/3 size if you use tantalum smd.
So where is there room for these parts.
No,yellow area is place for battery.
Would you like to have me keep on guessing ?
Or do you have an area that is suitable for a booster ?
-max-1 year ago
Buck and boost converters take a good amount of space. You need a thick PCB to mount all the parts, a chunky inductor, some capacitors, diodes, maybe resistors, the converter chip itself, all that together will simply take too much space. There almost isn't even enough room in a modern phone to stick even a paper thin (literally!) business card! Let alone another PCB... Unless you get a smaller battery and create a little space in the phone.
-max-1 year ago
There are these things called OTG cables, often sold with a small microUSB type B on one end, big female USB on the other (the kind that stuff plugs into.) Almost all modern phones, even old ones already have a built in boost converter for USB master support. (So that you can connect external devices to your phone, like flash drives and the such.)
-max-1 year ago
Why? What for? Where? Current requirements? Noise level requirements?
PavleP (author) 1 year ago
This is my android.
Why did you take apart your phone?
PavleP (author)  Yonatan241 year ago
To see where can I put converter.
What do I need to make boost converter that will be inside my android????
I want to put converter inside my android.
I doubt there is any room inside even for three grains of sand !
iceng1 year ago
Here is an excellent ible about how to build just such a converter
https://www.instructables.com/id/MintyBoost!---Smal...
Or if you don't want to do the tin foil part
https://www.instructables.com/id/MintyBoost!-Kit-V1...
A....
Look for "Mintyboost"
