I have an exceed sunfire buggy 1/10th and I am planning on getting a brushless upgrade. I don't know if the battery and car itself can handle the one i want. I have a 7.2v 4200mahNiMh battery pack and the motor I want to get is a 5.5T 6000kv motor. I was wondering if anyone knew if my car could handle that. If it couldn't, would a 8.5T 4000kv motor be better? And how fast would the second motor go? Please comment soon if you know anything about these motors.
Either one of these should work just fine. Less run time probably than what you have now but maybe not much less.
What you will have is more control problems because these are probably alot more powerful than what you have now and the wheels are going to break loose easier.
Bio:I have moved on to better things...aka YouTube. So I will most likely not reply to any comments, sorry for any inconvienience. If you have important questions, you can go to my youtube channel (MagmaR...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
the 4000kv has more torque
the 6000kv has more rmps
it depends on the gearing of your car, the aerodynamics of it, and other factors
It think your battery can handle it
4000 takes up to 9.6 volts and more torque
6000 takes up to 7.2 volds and more speed.
I did the calculations and figured the 6000 goes 45mph and the other goes about 35 mph.
I already did all the calculations what I'm asking is if you thing my battery and the car itself like the gears could handle it.
if the gears are stock, then i don't see a problem
What do the timings do? Like how you can program the esc and ther'sdifferent timings like 0.0 and 2.5 all the way up to i think 15.0?
should get this
What I need to know is if the battery and car's gears and stuff can handle the 6000kv or if I should stick with the 4000kv.
