Building a cantenna - choice of coaxial cables?
My goal is to build a cantenna to receive WiFi signal, and transmit it via the coaxial cable to bypass a thick wall in my house, and broadcast it through an antenna in the destination room.
For those who don't know what a cantenna is, take a look here:
http://www.vias.org/wirelessnetw/wndw_06_08_04.html
I read a few other tutorials like the one above, and the only thing I'm not sure is what kind of coaxial cable I should use.
For example, I found this one on ebay:
http://www.ebay.ca/itm/3M-6M-9M-Antenna-RP-SMA-Extension-Cable-for-Wi-Fi-Router-SMA-Coaxial-Adapter-/370811993692?pt=LH_DefaultDomain_0&var&hash=item56561dfe5c&_uhb=1
Would this RP-SMA type work for my application?
Also if I attach an antenna at the end of the coaxial cable, assume I have good impedance matching, how good would the signal be when I broadcast it in the room?
Thanks for your response!
Make sure its "characteristic impedance" is 50Ohm.
Steve
Any shielded coaxial cable will do.
