Building a robot with an Arduino, Motor Shield, and PIR Sensor
Hi. I have been trying to correlate the movement of my robot based on a PIR Sensor. Specifically, I just want my robot to move randomly (forward, left and right) whilst stopping on a regular interval (say every 5 seconds) to activate the PIR Sensor to check if anything's moving. However, I can't seem to make anything move and even the PIR is not checking on anything on my code.
Here's a list of what I am using
* A standard Parallax PIR Sensor
* Generic Motor Shield that drives 2 DC Motors. Uses pins  8,9,10,11.
* Arduino Uno R3
CODE:
Since I have yet to gather enough understanding on how to make time intervals on code, I am only trying at the moment to make the motors move once the PIR detects something. Here is my (non-working) code so far. (I only mixed and modified some tutorial codes I've found and added some of mine. Credits to their owners.)
int ledPin = 13;                // choose the pin for the LED
int inputPin = 2;               // choose the input pin (for PIR sensor)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the pin status
int speed;
void setup() {
  pinMode(ledPin, OUTPUT);      // declare LED as output
  pinMode(inputPin, INPUT);     // declare sensor as input
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  Serial.begin(9600);
void loop(){
  val = digitalRead(inputPin);
  if (val == HIGH) {
    digitalWrite(ledPin, HIGH);
    digitalWrite(8, LOW);
    digitalWrite(11, LOW);
    for (speed=0; speed<256; speed++){
      analogWrite(9, speed);
      analogWrite(10, speed);
      delay(10);
    for (speed=255; speed>0; speed--){
      delay(10);
    digitalWrite(8, HIGH);
    digitalWrite(11, HIGH);
      delay(10);
      delay(10);
    if (pirState == LOW) {
      Serial.println("Motion detected!");
      pirState = HIGH;
  else {
    digitalWrite(ledPin, LOW); // turn LED OFF
    if (pirState == HIGH){
      Serial.println("Motion ended!");
      pirState = LOW;
I tried the code and made some corrections and now it works. The car now runs for a short while whenever a motion is detected on the PIR sensor. That's basically how I programmed it to be for the meantime just to see if the shield and PIR Sensor work. However, how do I go into making the car to do these things:
1.  Run randomly for 5 seconds (forward, left and right)
2. Activate the PIR once the wheels have stopped. Then run another DC motor once motion is detected.
3. If no motion is detected on Step 2, Run step 1 again.
Thank you very much!
