loading
CMOS vs TTL? Which Is Better?
What are the main differences between CMOS (Complementary Metal-Oxide-Semiconductor) and TTL (Transistor-Transistor-Logic).
The things I want to know:
  • Which type do you use?
  • Which kind do you prefer?
  • Which type do today's computers use?
  • Are CMOS and TTL compatible?
These are the few things I know about them:
  • CMOS ICs (overall) will draw less current compared to TTL
  • CMOS are less picky in regard to their voltage supply.
  • It seems like most people like CMOS more than TTL.
Thanks!
Comments, answers, and everything else is appreciated!
Picture of CMOS vs TTL? Which Is Better?
You're way out of date ! TTL: died out years ago, to be replaced with LS, ALS and F series, or even HC series logic.
4000series CMOS has a special place, because its extremely low power consumption and wide supply range, at the expense of speed - CMOS tops out at not much more than 1 Meg.
Try this Wikiarticle
http://en.wikipedia.org/wiki/Logic_family
jensenr30 (author)  steveastrouk6 years ago
so do you think the F series is ok to use? i have a few F series chips and they are working good so far. They are cheap and can get into the hundreds of MegaHertz range.
I guess what I'm asking is this: are F series chips acceptable?
What do you mean by "acceptable" depends on what you want to do ! Interface to a multi gig CPU and 4000 series wouldn't work, but F series won't run on a lemon battery.
TTL is DEAD. "Cmos" is what we use inside most modern processors anyway, "4000" series is Cmos, but its not all there is.
Steve
Thank you for prompt replies and your advise. It 'shant be wasted!
+1. Note that there are versions of the newer CMOS chips which have input/output circuits compatible with old TTL chips, if you want to continue playing with them.
CMOS is much less static-sensitive than it used to be -- I regularly handle CMOS electronics, including expensive PC components, without worrying much about it -- but a grounding strap (see much discussion in the past) is good cheap insurance.
jensenr30 (author) 6 years ago
awesome! thanks for the in-depth answer! this helped alot, man!
I'm selecting this as the best answer!
Heh, heh. so true.
