CO2 canister discharge for arm mounted gun?
I'm looking to modify a simple airsoft gun for the purposes of making the needed weapon props for a assassins creed costume a friend of mine is working on.
With that said, the arm cannon/crossbow thing (sorry, I sadly never played the game!) is one I'm playing with now, and I got to thinking about taking a simple CO2 powered airsoft gun, and modding the barrel to take softer projectiles, and to be mounted to someones wrist.
The question being: would the discharge from a CO2 cartridge harm someones hand? There will be leather between gun and wrist, by the way.
Aug 7, 2012. 1:55 PMcrashtestmonkey says:
If you're mod'ing an Airsoft pistol, the escaping gas from the muzzle won't do you any harm. Just make sure you insulate the cylinder to stop it freezing anything it comes into contact with!
Jul 29, 2012. 12:46 PMonrust says:
http://stcvalve.com/Process_Valves.htm?gclid=CJiGt-XSv7ECFSQ0QgodOgwApg
Jul 31, 2012. 6:37 AMonrust says:
That is a gas discharge valve actuated by a low voltage solenoid. If you go to the link, I poorly provided, there are hundreds to choose from. They may not be cheap but it may be what you need. There are some made in plastic but you will have to look into the specs. Good luck and don't shoot your eye out ;)
Jul 28, 2012. 8:44 PMRe-design says:
If it discharge more than the normal amount there would be a danger of extreme frostbite. Anything you build should protect from that.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
