Can I etch silver using salt?
Hiyadudez7 years ago
Here is what a quick Google search bar provided:
http://www.google.co.uk/search?hl=en&q=how+to+etch+silver+using+salt&meta=&aq=f&oq=
Hope this helps!
squeekysqueeks (author)  Hiyadudez7 years ago
Excellent!  Many thanks.
Best answer?
No, regular table salt (NaCl) will not etch silver at all. The best you could possibly hope for would be a microscopically thin layer of Silver Chloride on your etch lines, which would prevent any further etching. Even that's not terribly likely.
Your best bet for safely etching silver is Ferric Nitrate. Here's a supplier (US and Canada only).
http://secure.sciencecompany.com/Ferric-Nitrate-125g-P6384C670.aspx
Thank you so much but unfortunately I'm in the Uk :o)
OK, then perhaps this one?
http://www.silverprint.co.uk/ProductByGroup.asp?PrGrp=49&sort_dir=0-0-0&sort_column=7-8-0&Start=50
You want the listing for Iron 111 Nitrate Nonahydrate - same stuff, different name.
lemonie7 years ago
I think not. Silver is one of those metals that's quite resistant to corrosion.
What do you want - surface patterning or etched right through?
L
squeekysqueeks (author)  lemonie7 years ago
Surface etching - but I was wanting to avoid using acid.  Thanks for your response though.
