I dont know the mechanics fog machines,so heres a problem u probably already heard,or know about.. I have a cheapy 400 watts Gemmy (about 6 or 7 years old). I pulled it out of the attic thinking it needed a good cleanout before halloween. I mixed up a 50/50 bottle of white vinegar and distilled water - turned it on and got one good 20-30 second burst from it.On 2nd burst a little leftover came out then nothing.Still heats up hot and I can hear pump humming when i trigger the remote. Next, I empty the tank and tried straight fog juice and still nothing.I emptied the tank and cleaned the tank filter tried it all again and still nothing...Could it be somewhere in the solid copper tubing from the pump to the heater and how do I clean that? I did however store it without fog juice in it..(empty),could that a cause of problum ? Please help.. TKS.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
So you dont think somthing might be clogging the copper tube? But,if its the pump,it woulnt be worth fixing-would it?
