loading
Can I make a photo-flash capacitor bank (20 caps) charge faster by wiring the charger in parallel with another charger?
If so, how many chargers could I put together?
iceng5 years ago
YES you can.
I would worry about the chargers damaging each other, Unless
there is a diode in series with each charger.
"how many chargers could I put together?"
How strong are you ? :-)
The only limit on how many chargers is $$ and available power.
How long does it take to charge ?  What voltage ?
Why is this important to you ?
A
Stuffses (author) 5 years ago
So, I would wire the chargers in parallel right? That would still get 330 volts from the chargers but a higher amperage ( I think).
So then, where would I put the diode? And how good would the diode have to be?
iceng Stuffses5 years ago
You need a 400V 1A diode 1N4004 or 1N4005 or 1N4006.   A
Stuffses (author)  iceng5 years ago
Wow, I just happened to have 2 1n4004`s on my desk. They are the only diodes I have.
yes, ive done it before, i had 5 in parallel and about 30 caps. its dangerous, i accidentally shorted it blew up in my face, my ears were ringing for 3 hours. be careful, im guessing your making a coil gun.
What happened to the shorting item, was it a wire ?
You may have a bit of UV burn.
A
piece of solder fell on it.
Solder is cool when vaporized !
Also makes you clean your area.
Like playing with NIB magnets of over the ¾" size.
Keep Living...
A
