loading
Can I place two speakers back to back in a box, any issues being too close or touching?
2.5w 8ohm 3" speaker in a plastic box 1cm apart, possible to operate?
Kryptonite7 years ago
Yeah that'd be fine, the magnetic force doesn't effect the internal moving piece that's attached to the diaphragm on the other one, well it might but not significantly enough to make the sound different.
I tried because I wanted a set of speakers for my computer, I used 2.5" speakers, 2.5w 8ohm if that helps.
celalboz (author) 7 years ago
Thanks a lot all of you, box is 3"x6"x7" and speakers (2.5" 8 ohm) are not touching, 2 cm apart back to back.
thanks again..
jeff-o7 years ago
Should be fine, as long as there isn't a direct short.
orksecurity7 years ago
Not sure whether you'd be risking phase effects. Depends on the size of the box...
