Can I power household fan with energy from a solar panel, or do I need converter between the fan plug and the solar ?
tylervitale6 years ago
You need a converter.
Household fans run on alternating current, and solar panels generate direct current. The mechanisms by which AC and DC motors work are very different from each other. If you want to power a household fan, or one that is plugged into a wall, you'll need a DC to AC converter.
kostya8 years ago
You may get a fan from a computer cooler. They run on 12VDC. It's not a problem to build or purchase a 12V solar panel.
dianakbrown8 years ago
Or purchase a fan that runs on DC rather than AC.
. heehee That would probably be the best option. ;)
NachoMahma8 years ago
. Solar panels put out DC. Appliances use AC. You will need an inverter to convert the DC to AC.
