loading
Can I reverse servo direction in Arduino?
On my robot, both servos move clockwise. Is there any way in the  Arduino Environment to reverse the direction of one, to make it move counter-clockwise?
gmxx7 years ago
 you could use the map function to remap the extremes of the servo, or give it the alternate value. what are the servos used for?
DELETED_afw11 (author)  gmxx7 years ago
They are being used as a motors and wheels for my Arduino based robot, one on each side of the robot. Because I flipped it, one servo is now going in the opposite direction.
so you have continuously rotating servos? feed the servo the inverse value. using pwm on my arduino, one servo is mapped to 1-180 degrees by default. for the flipped servo, feed it the values from 180-1 (so that one servo will get 180 degrees sent and the other is given 1)
If it bugs you to have to send two values like that, use the map function to map all the values from 1-180 to 180-1. then both will have te sam mapping scale, but one will receive the flipped values
