Can I spice hdmi cabes together to run 2 devises throught 1 monitor?
Hi, I have both my xbox and raspbeerry pi runnning through the same monitor. I am sick of swapping cables everytime I want to change devise. Anyway can I connect another HDMI cabe to build a Y lead so that I can connect both devises to a monitor (only 1 devise will be powerd on at a time). Will this be likley to damage either devise?
http://dx.com/p/hdmi-to-2-hdmi-split-y-cable-30-5cm-21761
Jayefuu4 years ago
No I think that allows you to use two outputs on one input, ie multiple screens.
What you need/want is an HDMI switch. You can get a 2 input 1 output switch with an IR remote for $15-40. Google "HDMI 2 input switch" or "HDMI 2 input switch with remote" to find one in your area.
James
+1
HDMI is not 'y' compatible in spec. The devices won't even work with HDCP encrpytion because both devices have to share the data lines and each has a unique id = each has a unique decryption key.
Need a proper hdmi splitter to split, and a proper switchbox to select individual inputs.
