3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Can I use a brushed DC motor directly without a speed controller?
The hobby shop people convinced me that there was no way to hook up a regular motor to my receiver without a ESC.  Even if the motor is all-on or all-off, I don't care.  I just want to be able to control it without a speed control.  Please help me!! I have faith in you people!!  Thanks in advance.
Jun 22, 2010. 12:04 PMWillard2.0 says:
Here is a diagram of the microswitch setup rickharris mentioned.  Take a look at the MAG Speed control midway down the page.  All you need is a servo and you are good to go.
Jun 21, 2010. 11:06 PMlemonie says:
You need some kind of power-handling device to run the motor.
What output do you get from the receiver (see rick') that you want to use for this motor?
L
Jun 21, 2010. 10:39 PMrickharris says:
Your RC receiver outputs a pulse of varying width (assuming not a digital receiver) this pulse is converted by a servo into a position. Where you may have a digital channel controlled by a switch the pulse is then either Max or Minimum - but still a variable with pulse.. You could however, attach a servo to operate a micro switch at each end of travel and so control your motor on and off. but you still need the servo to translate the received pulse into action. With a little research into switching you can also get the motor to go back and forwards using 2 micro switches and an H bridge type of set up. Google Hbridge.
Jun 21, 2010. 5:49 PMgmxx says:
to an rc reciever? yes and no. yes, you can hook it up without an ESC, but it requires a pwm controlled relay or similar device. so, you still have to hook it up to something in addition to the reciever.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
