loading
Can I use a circuit breaker - 220v 50hz -, in a network of 110v, 60hz? What kind of problem I could have?
Vyger2 years ago
The standard power panel in the US is divided into 2 power busses, if that is the correct word. An incoming 220 line is split into two to make 2 110 sides. A 110 breaker connects from one side of a 220 line to the central ground. A 220 breaker connects from one line of the 220 to the other line of the 220. So it is not split. The panel can produce 220 this way but the 110 breakers are only using half of the 220 line. It is usually balanced in the box by having breakers on alternating sides. A panel is designed to have both 110 and 220 voltages but a 220 breaker will always be 220 volts. You can't reduce it down because it is drawing from both sides of the incoming line.
2 power busses
Try Phases.
seandogue2 years ago
No. It would not be safe, and it would not pass inspection.
iceng2 years ago
Depends on the voltage and frequency involved.
When contacts open Magnetic arc suppression is more difficult at lower frequencies. As an example;
The GA75-10-00 breaker is rated 210V @ 50HZ and 240V @ 60Hz...
The voltage isn't the determining factor. Is the breaker compatible with your panel and what is the current rating on it. It trips based on current flow through it not the voltage.
