Can Someone Modify an Arduino Sketch For Me?
I recently got into Arduino, and my first long term project is an autonomous roaming robot. Now, I've been in electronics for a while, so the actual building of the thing was not a problem....but the programming is.
I've found a couple examples of codes online, but they all use Sharp IR sensors, whereas I have a Ping))) Ultrasonic sensor. I was wondering if there were any Arduino experts out there that could modify a sketch that I found to only use the Ping))) instead of the IR sensor(s).
This sketch actually uses both, and would be perfect if the Ping))) was used in place of the IR sensors, rather than with them.
If anybody could modify the sketch below to do as I said, your help would be greatly appreciated. Thanks.
Code:
int micVal;
int cdsVal;
int irLval;  // Left IR
int irCval;  // Center IR
int irRval;  // Right IR
int i;   // Generic Counter
int x;  // Generic Counter
int PLval;  // Pulse Width for Left Servo
int PRval;  // Pulse Width for Right Servo
int cntr;  // Generic Counter Used for Determining amt. of Object Detections
int counter; // Generic Counter
int clrpth;  // amt. of Milliseconds Of Unobstructed Path
int objdet;  // Time an Object was Detected
int task;  // Routine to Follow for Clearest Path
int pwm;  // Pulse Width for Pan Servo
boolean add;  // Whether to Increment or Decrement PW Value for Pan Servo
int distance;  // Distance to Object Detected via Ultrasonic Ranger
int oldDistance;  // Previous Distance Value Read from Ultrasonic Ranger
float scale = 1.9866666666666666666666666666667;  // *Not Currently Used*
int LeftPin = 6;  // Left Servo
int RightPin = 9;  // Right Servo
int PiezoPin = 11;  // Piezo
int PingServoPin = 5;  // Pan Servo
int irLPin = 0;            // Analog 0; Left IR
int irCPin = 1;            // Analog 1; Center IR
int irRPin = 2;            // Analog 2; Right IR
int ultraSoundSignal = 7; // Ultrasound signal pin
int val = 0;              // Used for Ultrasonic Ranger
int ultrasoundValue = 0;  // Raw Distance Val
int oldUltrasoundValue;  // *Not used*
int pulseCount;        // Generic Counter
int timecount = 0; // Echo counter
int ledPin = 13; // LED connected to digital pin 13
#define BAUD 9600
#define CmConstant 1/29.034
void setup() {
  Serial.begin(9600);
  pinMode(PiezoPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(LeftPin, OUTPUT);
  pinMode(RightPin, OUTPUT);
  pinMode(PingServoPin, OUTPUT);
  pinMode(irLPin, INPUT);
  pinMode(irCPin, INPUT);
  pinMode(irRPin, INPUT);
  for(i = 0; i < 500; i++) {
    digitalWrite(PiezoPin, HIGH);
    delayMicroseconds(1000);
    digitalWrite(PiezoPin, LOW);
  for(i = 0; i < 20; i++) {
  digitalWrite(PingServoPin, HIGH);
  delayMicroseconds(655 * 2);
  digitalWrite(PingServoPin, LOW);
  delay(20);
  ultrasoundValue = 600;
  i = 0;
void loop()
  //Scan();
  Look();
  Go();
void Look() {
  irLval = analogRead(irLPin);
  irCval = analogRead(irCPin);
  irRval = analogRead(irRPin);
  //if(counter > 10) {
    //counter = 0;
    //readPing();
  if(irLval > 200) {
    PLval = 820;
    PRval = 850;
    x = 5;
    cntr = cntr + 1;
    clrpth = 0;
    objdet = millis();
  else if(irCval > 200) {
    PLval = 820;
    PRval = 850;
    x = 10;
    cntr = cntr + 1;
    clrpth = 0;
    objdet = millis();
  else if(irRval > 200) {
    PLval = 620;
    PRval = 650;
    x = 5;
    cntr = cntr + 1;
    clrpth = 0;
    objdet = millis();
  else {
    x = 1;
    PLval = 620;
    PRval = 850;
    counter = counter + 1;
    clrpth = (millis() - objdet);
    if(add == true) {
      pwm = pwm + 50;
    else if(add == false) {
      pwm = pwm - 50;
    if(pwm < 400) {
      pwm = 400;
      add = true;
    if(pwm > 950) {
      pwm = 950;
      add = false;
    delayMicroseconds(pwm * 2);
    delay(20);
    readPing();
    if(ultrasoundValue < 500) {
      cntr = cntr + 1;
      switch(pwm) {
        case 400:
          x = 7;
          PLval = 650;
          PRval = 650;
          Go();
          break;
        case 500:
          x = 10;
          PLval = 650;
          PRval = 650;
          Go();
          break;
        case 600:
          x = 14;
          PLval = 850;
          PRval = 850;
          Go();
          break;
        case 700:
          x = 10;
          PLval = 850;
          PRval = 850;
          Go();
          break;
        case 950:
          x = 7;
          PLval = 850;
          PRval = 850;
          Go();
          break;
  //Serial.print("clrpth: ");
  //Serial.println(clrpth);
  //Serial.print("objdet: ");
  //Serial.println(objdet);
  //Serial.print("cntr: ");
  //Serial.println(cntr);
  if(cntr > 25 && clrpth < 2000) {
    clrpth = 0;
    cntr = 0;
    Scan();
void Go() {
  for(i = 0; i < x; i++) {
    digitalWrite(LeftPin, HIGH);
    delayMicroseconds(PLval * 2);
    digitalWrite(LeftPin, LOW);
    digitalWrite(RightPin, HIGH);
    delayMicroseconds(PRval * 2);
    digitalWrite(RightPin, LOW);
    delay(20);
void readPing() {  // Get Distance from Ultrasonic Ranger
timecount = 0;
val = 0;
pinMode(ultraSoundSignal, OUTPUT); // Switch signalpin to output
/* Send low-high-low pulse to activate the trigger pulse of the sensor
digitalWrite(ultraSoundSignal, LOW); // Send low pulse
delayMicroseconds(2); // Wait for 2 microseconds
digitalWrite(ultraSoundSignal, HIGH); // Send high pulse
delayMicroseconds(5); // Wait for 5 microseconds
digitalWrite(ultraSoundSignal, LOW); // Holdoff
/* Listening for echo pulse
pinMode(ultraSoundSignal, INPUT); // Switch signalpin to input
val = digitalRead(ultraSoundSignal); // Append signal value to val
while(val == LOW) { // Loop until pin reads a high value
while(val == HIGH) { // Loop until pin reads a high value
  timecount = timecount +1;            // Count echo pulse time
/* Writing out values to the serial port
ultrasoundValue = timecount; // Append echo pulse time to ultrasoundValue
//serialWrite('A'); // Example identifier for the sensor
//printInteger(ultrasoundValue);
//serialWrite(10);
//serialWrite(13);
/* Lite up LED if any value is passed by the echo pulse
if(timecount > 0){
  digitalWrite(ledPin, HIGH);
void Scan() {   // Scan for the Clearest Path
  oldDistance = 30;
  task = 0;
  for(i = 1; i < 5; i++) {
    switch(i) {
      case 1:
        //Serial.println("Pos. 1");
        pwm = 1125;    ///  incr. by 100 from 1085
        break;
      case 2:
        //Serial.println("Pos. 2");
        pwm = 850; //// increased by 100 from 850
        break;
      case 3:
        //Serial.println("Pos. 3");
        pwm = 400;
        break;
      case 4:
        //Serial.println("Pos. 4");
        pwm = 235;
        break;
    for(pulseCount = 0; pulseCount < 20; pulseCount++) {  // Adjust Pan Servo and Read USR
      readPing();
      delay(20);
    distance = ((float)ultrasoundValue * CmConstant);   // Calculate Distance in Cm
    if(distance > oldDistance) {  // If the Newest distance is longer, replace previous reading with it
      oldDistance = distance;
      task = i;   // Set task equal to Pan Servo Position
  //Serial.print("Task: ");
  //Serial.println(task);
  //Serial.print("distance: ");
  //Serial.println(distance);
  //Serial.print("oldDistance: ");
  //Serial.println(oldDistance);
  distance = 50;  // Prevents Scan from Looping
  switch(task) {   // Determine which task should be carried out
    case 0:  // Center was clearest
      x = 28;
      PLval = (850);
      PRval = (850);
      Go();
      break;
    case 1:  // 90 degrees Left was Clearest
      x = 14;
      PLval = (650);
      PRval = (650);
      Go();
      break;
    case 2:  // 45 degrees left
      x = 7;
      PLval = (650);
      PRval = (650);
      Go();
      break;
    case 3:  // 45 degrees right
      x = 7;
      PLval = (850);
      PRval = (850);
      Go();
      break;
    case 4:  // 90 degrees right
      x = 14;
      PLval = (850);
      PRval = (850);
      Go();
      break;
frollard8 years ago
Comment out the 'look' procedure call in void loop()' with //.
See if the sketch still runs - it looks like it uses look for IR only, and if it still works in a rudimentary sense just moving based on obstacles.  Look just makes sure you're not right up against an object that the ping won't catch.
Recommended:  Get some ir sensors - they are cheap!
sboy98697 years ago
g'day, I'm very new to coding as well, but I think if you simply remove from the code, anything pertaining to the IR sensors, then that should do it..... As if they were never there.
This code actually looks very much the same as the one I have for my beast that I want to change from using continuous rotation servos as the drive motors and inserting the right code to run a pair of DC motors.
Stephen
Re-design8 years ago
Are you a member of an Arduino forum?
punkhead58 (author)  Re-design8 years ago
I am, but I'm posting on multiple forums so I get a wide array of answers to choose from.
Good plan.  I just wanted to point out that not very many of us here are Arduino whizzes (a few are) and wanted you to get a good answer.
Have you got 4 "Ping" sensors ? If you haven't, how do you replace the IR ?
