loading
Can a 9V battery power a Bluetooth module (HC-05)?
I am trying to power Bluetooth module and the Arduino using a 9V battery. So tried to use a voltage regulator (KA7805) with 25volt 100miro farad and 63V 1 micro farad capacitors. I checked the circuit connecting these components using multimeter, it showed 5.06V as the output. But the problem comes when I connect the Bluetooth module to this output, which turns off after quickly. I checked the voltage at the bluetooth which is reducing quickly from 5V-2.5V in a matter of seconds and since the operating voltage of Bluetooth module HC-05 is 3.6V-7V, it turns off. I am not clear why this circuit behaving this way. Same output when I connected to the Arduino, it works seamlessly. Please let me know what are the mistakes that I need to rectify for this work. Thanks in advance
Watch the battery voltage as the supply drops out. My guess is the current draw is too much for the battery and regulator
iceng2 years ago
YES, we are thinking that the unit is drawing enough current to pull down the week battery.
