loading
Can anyone design me a circuit?
Hey Guys, I'm back asking questions (yay). I was wondering if anyone could design me a circuit for 6 Blue Leds in parrelel running from a 9v battery with a 555 ic to blink them.
Thanks in advance.
-Prickly Potato
iceng2 years ago
This will use less power then 6 parallel !
shahryar.adil.3 (author)  iceng2 years ago
Sorry I accidentally deleted all the comments. I was saying that "Yes please make the decision for me", oh and another thing the six LED's will be arranged in the shape of a smiley face.
Here are your circuit values.
It is best to change C1 (o..47 to 100 uF ) if you want to alter the timing currently set to about 1.1 sec.
If you are more adventuresome the Bowden calculator lets you change resistors and see the timing.
http://www.bowdenshobbycircuits.info/555.htm
The o.01 uF is for stability and does not affect the blink rate.
iceng2 years ago
Where the LEDs, capacitors and the 555 IC all meet :)
Can you give me the values of the potentiometers i would need to control the blinking of LED's?
How long is a Blink ?
How often do you want it to Blink ?
I have tried to read your mind but it is closed to me..
The values of fixed resistor for a normal blink rate?
You must tell me what you want this normal blink rate to be then I can calculate the resistors to make that 4 U.
Some people make the blink 3.33 ms and the duration 4 hours other people blink for one second repeating every thirteen seconds as a normal blink rate....
Are you unable to make such a decision and want me to do that for you ??
Yes please
BTW the six leds will be arranged in the shape of a smiley face
iceng2 years ago
Gnd
Thanks ! :)
This circuit by Michael Ringe uses a simply flip flop to charge two capacitors to the level required to flash a white or blue LED.
It can flash for several weeks on a single battery.
You can check if two of your LED's still flash sufficient when in parallel but it would be best to have once circuit per LED.
Did you consider a cheap heap or bicycle lamp?
They come with 3 or more white LED's and run on 3-4.5V, should be no problem to add a few more LED's to them and the battery pack uses little more space than a 9V block battery.
Two transistors, some resistors and capacitors, no need for a 555 to blink some LED's ;)
OK .... You should draw it up, as I have not seen it in any of your ibles.
But first, I noticed you have ammonia experience, maybe you could help answer my question. https://www.instructables.com/answers/Can-someone-h...
kjsrocks2 years ago
Google is your friend!
rickharris2 years ago
Need more information:
Forward voltage
Current
Blink rate.
You 9 volt battery is very current limited and won't run them for long, perhaps not at all.
http://led.linear1.org/led.wiz
https://www.google.co.uk/search?q=555+astable+circ...
The 555 astable (no stable state so it just keeps flip flopping back from on to off - in fact in my day was called a flip flop) is very common circuit above. You need to work out the R and C values for the blink rate you want.
