loading
Can anyone help me with this type of LCD?
Hi everyone.
I have this LCD with 21 pins. On this PCB its writen AZ-2060 LCD driver. I have no idea what kind of LCD is, i have it from a printer i think (the printer didn`t work), because i like to save parts from old things. If anyone know what kind of LCD is , please tell me, because I have an Arduino and i like to play with it and in the same time learn programming. Maybe i can use it with my Arduino.
Thank you very much !!
Picture of Can anyone help me with this type of LCD?
danyelo (author) 22 days ago
thank you very much guys !! You are right , i've remembered. But my questions is (i have no idea in this field, but i wanna learn) can i use it with my arduino (i think the answer is easy "yes, of course" , but how? I saw the LCD_DATA , WR and CS. I have i little clue , but i'm not sure if its the right one. Can you halp me a little please?
YOu need to find a data sheet for the display - without that you have no idea what pin goes where, what the codes are for the display ETC. I would start with AZ the apparent maker.
Ask - you may be given.
danyelo (author)  rickharris22 days ago
You are right. I was thinking maybe i can use this driver , this pcb, because it has 3.3v , gnd , LCD_DATA , LCD_RW and LCD_CS. i found something about this pins and this kind of drivers, but not a single exemple what i must do with this LCD_DATA ...maybe i'm a little stupid , but i have no experience with programming, i mean that i cant create a program by myself...thank you very much for the help !!
then your in a dark hole! Actually programming isn't that difficult, Initalisation data then the display data is sent
http://www.picaxe.com/docs/picaxe_manual3.pdf
may illuminate things slightly.
+1
I often try initialization from three other LCD manufacturer types and there is a commonality that helps work out the full initialization sequence.. Of course graphic units are harder and very time consuming.
danyelo (author)  iceng21 days ago
I know, but i like playing with stuff. Thank you very much for the help !
petercd23 days ago
Looks like the LCD from the top of the Philips CD /Radio player, the AZ 2060.
http://www.radiomuseum.org/r/philips_cd_soundmachine_az206000c.html
rickharris23 days ago
