Can anyone tell me how to repair an emergency light that doesn't recharge?
jovenhatsjr@gmail.com
ScottW462 years ago
Hi! I have the same question but can't find any solution for it! Something happened with the emergency light, maybe something with bulb, I have this type http://hardware.nl/noodverlichting/van-lien/aqualux/1132151.html and also last time it was overvoltage that made light work more then 3 hours. I guess it is the main reason of it broke!
microcal8 years ago
Be careful of high voltage and be sure your knowledgable before you poke around. Find and remove the batteries. Ensure the system is in charging mode. Measure the voltage at the battery terminals. You will have to get a number off the battery and google it. It should be a few volts above the expected sum of the battery voltage. and if not the charge circuit is dead, supply voltage is gone or the charge circuit is dead. If the voltage is good then replace the batteries
jovenhatsjr (author)  microcal8 years ago
Thanks o lot my friend for the help hope you wont mind my asking , what shoul i use in testing AC or DC. You see am really poor on electricity
ewalk8 years ago
How expensive is the emergency light? If it is a cheaper one, they usually come with a battery and a crank. Once the battery dies, you are left with the crank only. There is an Instructable on how to make a rechargeable emergency light. Hope this helps!
jovenhatsjr (author)  ewalk8 years ago
thank you very much for me here in the Philippines 1000pesos is already expensive, but this is the kind of emergency lights that is usually installed on the walls and lights automatically when Brown Outs (what we call here when power from supplying companies interupted).
