Can i run Windows Xp on a server?
Since a server is basically a computer, can i run windows XP on it?
Thanks!
9
answers
Answer it!
As for your original question, this model lists only 64-bit server editions of Windows as well as Red Hat Linux; from a hardware standpoint, any Windows (XP or higher) or Linux distro should work fine. I think they list it that way because they figure it's a server, and people will only be interested in dropping a server OS on it.
If you choose 64-bit XP, you'll want to stick with XP Pro 64 - not XP 64, as there is a clear difference. XP Pro 64 is pretty much identical in build to Windows Server 2003, and it is still supported by Microsoft (whereas XP 64 is not). There are, however, known issues that have yet to be fixed with it. Therefore I would recommend Windows 7 Home Premium; it can be easily stripped down to only occupy 300 MB RAM or less (which isn't that much more than XP), and the optimizations in memory management make it just as zippy as a clean XP install.
Or you can go the Linux route, it don't make no nevermind to me.
oh, and do you know if regular pci cards are compatible with pci-x?
Stripping down Windows 7 gets as shallow or in depth as you want; it depends on how militant you are about ridding fluff. A fresh installation of Home Premium (with drivers only) typically takes up between 700-800 MB RAM, including the Aero interface. If you disable the Aero interface, get rid of any unnecessary Windows components, and disable all but the essential services, you'll get close to where you want. It also helps to make sure newly-installed software is prevented from starting up automatically with Windows. If you want specifics, let me know.
Rory
something like this
I don't really want fancy hyper fast server, i just need something that will encode videos, and preform other tedious tasks
I wanted so stick with a GUI, because it is easy to use, drag, drop, and click
Your instinct is right - sure you can.
L
