3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Can i use c41 Film in a 35 mm camera?? and if not is there a way to mod the film to use in a 35mm camera?
Feb 14, 2010. 1:49 PMlemonie says:
What is c41? Can you point to a specification, I can't find one...
L
Feb 16, 2010. 5:43 AMJPphoto87 says:
 Just remember not to shoot anywhere as near as much as people do with digital, or it'll get expensive fast.
Feb 14, 2010. 2:51 PMHarrisCreekCentral says:
C-41 is the title given to the chemistry required to process the film.  This has nothing to do with the physical make up of the film itself.  A B&W c-41 film only means that when it is taken into the lab for processing, it is processed in the same chemistry that you normally process the regular color film.
Feb 14, 2010. 1:36 PMRe-design says:
C41 is a process.  It is the way the film is designed and the process to develope the image.  If the film is sized for a35 mm camera then it will work just fine.
If it is another size then you are out of luck unless you can slit the film and put sprocket holes in it.  Most 35 mm cameras use the sprocket holes to stop the film in the right spot and cock the shutter release, not the shutter itself but the release that keeps you from making a double exposure on the same frame of film.  In other words you won't be able to release the shutter without the sprocket holes since there will be nothing to turn the toothed gear.
There were a couple of cameras that did not use the sprocket holes so it would work for those.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
