Can portland cement be mixed without sand or gravel?
7
answers
Answer it!
You can, but cement on it's own is not a good material for anything really.
What is wrong with mixing in sand (which is much cheaper than cement)
L
Aggregate is added to cement to give it strength. Without aggregate, you're basically going to have grey plaster with little inherent strength for both tension and compression. Even small aggregate, sand and pea gravel, will make a significant difference in the strength.
Aggregate to cement proportions should be about 3 parts aggregate to 1 part cement by volume for field/hand mixed concrete. Only enough water should be added to afford workability and eliminate voids in the mix. The less water you use, the higher the strength of the cured concrete.
There are additives you can mix with the concrete for additional workability and strength. Check with your retailer for information on this.
Last, you can buy ready mixed, dry concrete, usually called Reddy-mix and Sackcrete. Easier to use but significantly more expensive than buying the components and preparing the mix yourself.
Do I really understand that you can see yourself mixing cement inside your house?? Tolerant wife is all I can say.
You can whittle a stick over a waste-paper bin in almost absolute silence.
