Can the CP2101 USB to serial IC be used to connect a microP directly to a PC without an RS232 port and a MAX232 IC?
Sparkfun makes an excellent breakout board for Silicon Laboratories' CP2101 IC. It looks like this board could be used to connect a PC to your microprocessor through a USB port without having to use a MAX232 IC to convert the TTL voltage levels to the serial port voltage levels and then a USB to serial converter. Drivers are available so the PC sees the CP2101 as a COM port so hyper-terminal could be used to communicate with the microP. The 'S' in USB stands for serial, it should would be nice to connect a PC to a microP using only one piece of hardware. Am I right about the CP2101 providing this ability?
everythingRF says: Sep 15, 2009. 2:51 PM
I believe the answer is yes. Take a look at the document labeled "USB Driver Installation Information" on the SparkFun page you linked to. It says, "You can now use Windows HyperTerminal or your favorite terminal program to connect to this device via the com port number."
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
