3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Can using logarithms overcome scope insensitivity bias?
Say you perform the following type of psychology experiment:
  • You describe an undesirable event to people,
  • tell them that X instances of the event can be prevented, and
  • ask them what they would be willing to pay in order to prevent those X instances.
  • The responses you get (Y) are not even close to being linear with respect to X, but rather
  • the responses are roughly logarithmic. That is, X=ABY, or Y=logB(X/A) for some constants A and B.
So does anyone know of an experiment (or real-life situation) where subjects are asked to answer in terms of log(Y) instead of Y? Do such responses show a linear relationship to the corresponding X?
Apr 6, 2009. 12:18 PMkelseymh says:
Have you tried searching Google Scholar? It's a separate Google database strictly for peer-reviewed and related publications, including preprints (e.g., from arXiv) and conference proceedings. It isn't well known, unfortunately. It also has the limitation that a number of results (in particular, anything from Elsevier-published journals) are pay-per-view, so you don't get much beyond abstracts.
What I often do (for physics) is use Google Scholar to find interesting articles, then look for the corresponding preprints directly on arXiv.
Apr 4, 2009. 10:39 PMkelseymh says:
I don't know, but I would be willing to guess that if you tried to present people with log(x), you'd get a dilog response curve (i.e., log(log(x))). Human perception in general is driven logarithmically (consider e.g., sound perception in bels/dB, light intensity, and so on). The broad reason is that logarithmic response provides a huge dynamic range with roughly uniform sensitivity.
Apr 6, 2009. 8:42 AMkelseymh says:
You're right that logarithmic response isn't always the "best" design. However, we are, as you know, constrained by our history. Nature tends to re-use (and overuse :-) constructions and systems which are successful. My suspicion is that humans' "analysis" of numbers on relative scales (i.e., proportions, which leads to logarithmic sensitivity) is an example of reusing the same kind of brain structures that work for sensory information in a more abstract area. Doing something differently would require separate and special-case neural constructs for abstract numerical analysis. Humans haven't been doing numbers for long enough, nor are the "shortcomings" of our current system significant enough, for such a separate system to have evolved.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
