Can you hook up a propane tank in place of natural gas hookup?
For example, could you you connect a propane tank to something like this: http://bit.ly/fJG9VI It's a natural gas oven.
Re-design6 years ago
No.
I think the fittings are different to prevent this.
You can probably get a kit of parts to turn this stove into a propane burning stove.
The problem is that nat gas and propane burn differently and the regulator and other parts are specific to the gas to be burned.
.  +1. Not compatible, but conversion kits are available. Along with the fittings being different, you have to change out the orifice(s) (propane has a higher BTU content) and possibly the whole burner assembly.
It burns at a different speed, so the orifice size changes
you "could" but it would asplode or not ignite :D
I do believe propane to be more potent, and usually at higher pressure (liquified) needing a much smaller pinhole regulator.
Natural gas, primarily Methane = C1H4
Propane = C3H8
Different ratio = different stoicheometric ratio to burn completely = different air mix = different everything.
