Can you plug a tiny terror head into any amp cabinet?
 I have a tiny terror orange amp but do not have the orange cabinet...  I do not want to buy the orange cab as it is too expensive.  Can I build one?  What can I use for it?  Any advice?
iamtoats7 years ago
 I have a nice instructable for a cab, if you want... It's ported, and sounds really big!
 I will also make a Mesa Boogie Rectifier 2x12 clone instructable this summer, if you can hold out....
KyF1 iamtoats3 months ago
did you end up making those mesa plans??
rickonicko (author)  iamtoats7 years ago
Thank you I am building your amp cabinet.  What is the speaker?  I am using a 8 ohms and 16 ohms then I will have a swicth that will determine to use the 8 ohms speaker and the 16 ohms.  Would this work?
 The one that I have up now, You only get an 8 or 16 ohm speaker, and stick to it... It takes an EV EVM12L or an Eminence Delta Pro-12a
The one I hope to get moving early this summer, yes!
I plan to use two Celestion V30's, but any 12 inch speakers should work. To have a switchable cab, you need to buy 8 ohm speakers, and a 5 amp DPDT switch. You can ONLY! switch between 4 and 16 ohms. So it can hook up to the 16 ohm output of your tiny terror. Switching to 8 ohms is not possible.... I dont think, unless you have a piezo, or something, but I cant be sure...
If you want plans for a 4x12 Marshall 1960a cabinet, which I believe Orange based their cab off of, here are plans I saved before they were erased for being too good.... I won't be making this one any time soon.
Crap, that's small......
If anybody wants the original .pdf, sand me a private message with your email address.....
Re-design7 years ago
You can use any speaker cabinet you choose, even if you build it yourself as long as it is either 8 ohms or 16 ohms.
You may plug in one 8 ohm speaker or one 16 ohm cabinet at a time.
Google "tiny terror manual" if you don't have one.  This is all detailed in the manual.
Looks like a nice amp.
rickonicko (author)  Re-design7 years ago
 Thanks.  I going to build a cabinet with a swicth from the 8ohms speaker and the 16ohms skeaker.
Thanks for the idea of the manuel...
