Can you put a key on a pocket bike?
Hi i was wondering if i could still keep the pullstart on my pocket bike, but make it so the key has to be in inorder for the bike to turn over, kind of like a kill switch any help would be much apreciated.
Burf4 years ago
Absolutely. I used to install them on some of my small engine generators, compressors, etc.
You can get anything you need from a simple keyed toggle switch up to an OEM ignition switch. For your purposes, a keyed toggle switch type should be suitable. You can get them at almost any small engine sales and repair shop/store for about $5 - $10 U.S.
Google "small engine keyed switch" and determine what you need/want.
jjames394 years ago
lolll im pretty sure that there are 2 wires (usually red and green) connected to the same plug coming directly from the engine, disconnect the plug and use the pull start. Or you have to do is rip out the ignition,just buy a new ignition module they arn't that expensive.. Good Luck! www.cusabio.com monoclonal antibody drugs
