Can't create shell?
When I try to form the shell after I select the top and bottom surfaces and enter the thickness I get an error message saying "The selected faces could not be offset. Try adjusting the offset/thickness value or changing the selection of faces."
JON-A-TRON26 days ago
This usually happens because the value you're trying to use as a shell thickness is too large for the geometry to be possible. Did you "try adjusting the offset/thickness value or changing the selection of faces"?
MSG56 (author)  JON-A-TRON25 days ago
I just went back into Fusion and opened this model. I went to the shell comment, selected the two surfaces and entered 1.5 mm and this time it worked! No idea what happen, but it's working correctly now. Oh well, thanks for the response. I greatly appreciate it.
