loading
Can you cut a bottle evenly lengthwise?
if you're talking plastic, use a bandsaw. If you're talking glass, use a diamond table saw.
Keeter8 years ago
If you're talking about a glass bottle, I'd suggest trying to score it lenthwise, then use the technique of thermal shock to snap it in half. That is when you heat the line with a candle, then dunk it in cold water, it should snap down the score line.
pyper8 years ago
Try filling it full of water and freezing it, then make a jig.
altomic pyper8 years ago
don't do this as water expands when it freezes. and glass doesn't expand.
110100101108 years ago
pypers solution looks good if it fails though do this cut a big hole in the side of the bottle (like canoe) but leave the bottom half (and more) intact fill with water to the wanted height and wait for water to calm down spray graffiti paint on the walls from inside so that it paints them above the water (a bit is enough and not too closely to not disturb the water) wait for graffiti to dry spill out water
