3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ceramic resonator vs. Quartz crystal for arduino?
Hey- I'm going to build some Arduino clones (as posted from http://fritzing.org/projects/barebones-arduino/ ) and was wondering if it would be better to use a crystal or a ceramic resonator. i will be ordering from Tayda Electronics (Ive ordered before, 10 days shipping for rock bottom prices, I'm ok with that) and the resonators and crystals are +-5c. difference, so I was wondering if I could use resonators, since they are a bit cheaper and I'm ordering a few (around 8). Which ones would be better? Also, does anyone know for the circuit from the above link would work with a 4.5v supply if I just left out the 5v regulator?
Many thanks- Astroboy907
Jan 23, 2011. 8:22 AMsteveastrouk says:
Use crystals, unless you are stuck for space and/or you can accept the higher drift characteristics and you are making 20,000,000 of them,
Typically, the capacitors used with a crystal are 22..33pF, but the crystal data and processor data should be checked.
Steve
Jan 22, 2011. 6:56 PMRe-design says:
In my experience, yours may be different,
Quartz crystals have two leads ceramic resonators have 3 or if they have two you must add 2 capacitors to make the work, making them three lead parts.
Ceramic resonators don't have nearly as close a tolerance as crystals have and in any use where frequency control is important they are less useful.
Jan 22, 2011. 10:32 PMfrollard says:
Again
Quartz = needs capacitors to 'start' the cycles= costs a few more cents, but are MUCH more accurate
Ceramic = will make it run, but don't expect any time-critical operations to be stellar (high speed communications, time measurement)
BOTH will be affected by temperature, but I forget which is more susceptible.
Jan 23, 2011. 4:15 AMsteveastrouk says:
Ceramic. Crystals are the gold standard.
Jan 23, 2011. 8:20 AMsteveastrouk says:
It usually tells you in the data sheet. Typically, they are between 22 and 33pF.
Steve
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
